Using MDX, you can replace every HTML element that Markdown renders with a custom implementation. This allows you to use a set of design system components when rendering Markdown.
// src/components/layout.js
import { MDXProvider } from "@mdx-js/tag";
import * as DesignSystem from "your-design-system";
export default function Layout({ children }) {
return (
<MDXProvider
components={{
// Map HTML element tag to React component
h1: DesignSystem.H1,
h2: DesignSystem.H2,
h3: DesignSystem.H3,
// Or define component inline
p: props => <p {...props} style={{ color: "rebeccapurple" }} />
{children}
</MDXProvider>
edit this page on GitHub
